Salta al contenuto principale
HP Pavilion 17-e146us Keyboard Replacement
Cosa ti serve
  1. HP Pavilion 17-e146us Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over.
  2. HP Pavilion 17-e146us Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion 17-e146us Keyboard Replacement: passo 2, immagine 2 di 2
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Keyboard Replacement: passo 3, immagine 1 di 1
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Keyboard Replacement, Keyboard: passo 4, immagine 1 di 3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: passo 4, immagine 2 di 3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: passo 4, immagine 3 di 3
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Keyboard Replacement: passo 7, immagine 1 di 2 HP Pavilion 17-e146us Keyboard Replacement: passo 7, immagine 2 di 2
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Keyboard Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Keyboard Replacement: passo 9, immagine 1 di 1
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Keyboard Replacement: passo 10, immagine 1 di 3 HP Pavilion 17-e146us Keyboard Replacement: passo 10, immagine 2 di 3 HP Pavilion 17-e146us Keyboard Replacement: passo 10, immagine 3 di 3
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 795
