Salta al contenuto principale
HP Pavilion 17-e117dx Service Panel Replacement
Cosa ti serve
  1. HP Pavilion 17-e117dx Service Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Service Panel Replacement: passo 2, immagine 1 di 2 HP Pavilion 17-e117dx Service Panel Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Service Panel Replacement, Service Panel: passo 3, immagine 1 di 2 HP Pavilion 17-e117dx Service Panel Replacement, Service Panel: passo 3, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Service Panel Replacement: passo 4, immagine 1 di 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Service Panel Replacement: passo 5, immagine 1 di 1
    • Remove the service panel.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 376
