Salta al contenuto principale
HP Pavilion 17-e117dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 17-e117dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 17-e117dx Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: passo 3, immagine 1 di 2 HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: passo 3, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Hard Drive Replacement: passo 4, immagine 1 di 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: passo 6, immagine 3 di 3
    • Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Hard Drive Replacement: passo 7, immagine 1 di 3 HP Pavilion 17-e117dx Hard Drive Replacement: passo 7, immagine 2 di 3 HP Pavilion 17-e117dx Hard Drive Replacement: passo 7, immagine 3 di 3
    • Disconnect the hard drive connector cable from the computer's system board.
  8. HP Pavilion 17-e117dx Hard Drive Replacement: passo 8, immagine 1 di 2 HP Pavilion 17-e117dx Hard Drive Replacement: passo 8, immagine 2 di 2
    • Lift the hard drive out of the hard drive bay by lifting up from the tab.
    • Remove the hard drive from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,922
