Salta al contenuto principale
Cosa ti serve
  1. HP Pavilion 17-ak008cy Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Motherboard Replacement: passo 2, immagine 1 di 3 HP Pavilion 17-ak008cy Motherboard Replacement: passo 2, immagine 2 di 3 HP Pavilion 17-ak008cy Motherboard Replacement: passo 2, immagine 3 di 3
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: passo 3, immagine 2 di 2
    • Remove eleven screws from the back panel.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Motherboard Replacement, Fan: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
  5. HP Pavilion 17-ak008cy Motherboard Replacement: passo 5, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement: passo 5, immagine 2 di 2
    • Disconnect the fan wire carefully so that the fan is longer connected to the motherboard.
  6. HP Pavilion 17-ak008cy Motherboard Replacement: passo 6, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the fan from the device.
  7. HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: passo 7, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Carefully detach the connector above the hard drive.
    • Remove the hard drive from the device.
  8. HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: passo 8, immagine 1 di 3 HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: passo 8, immagine 2 di 3 HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: passo 8, immagine 3 di 3
    • Disconnect all of the cables attached to the motherboard.
    • Many of these wires are delicate so be careful when unplugging them.
  9. HP Pavilion 17-ak008cy Motherboard Replacement: passo 9, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove eight screws from the motherboard.
    • Using the same screwdriver, remove four screws from the motherboard.
  10. HP Pavilion 17-ak008cy Motherboard Replacement: passo 10, immagine 1 di 2 HP Pavilion 17-ak008cy Motherboard Replacement: passo 10, immagine 2 di 2
    • Gently lift and remove the motherboard from the device.
Conclusione
Andrew Boardman
Membro da: 25/10/2021
487 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 93
