Introduzione
Incase of any damages that may occur to the shell of the computer, you can always replace the back panel. Be sure to use cation when unscrewing and re-screwing the back panel back in. You don’t want to apply too much force on incorrect angles to avoid stripping the screws. Other than that you should be on your way to replacing the back panel!
Remove eleven screws from the back panel.
Remove the back panel from the device.
