Introduzione
The rear plate acts like a shield. It protects your most important components from outside interference, like damage and to some extent, dust. This guide will show you how to remove it.
Cosa ti serve
Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
