Salta al contenuto principale
HP Pavilion 15-p214dx Disk Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, immagine 1 di 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, immagine 2 di 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, immagine 3 di 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-p214dx Disk Drive Replacement: passo 2, immagine 2 di 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Conclusione
Patrick Seaver
Membro da: 03/25/19
1.001 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 275
