Salta al contenuto principale
HP Pavilion 15-p214dx Battery Replacement
Cosa ti serve
  1. HP Pavilion 15-p214dx Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-p214dx Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
  2. HP Pavilion 15-p214dx Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-p214dx Battery Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
    • While holding the latch in place, remove the battery from the laptop's battery bay.
    • When inserting a battery into the battery bay, the battery release latch does not need to be held open.
Conclusione
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
Patrick Seaver
Membro da: 03/25/19
1.001 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 611
