Introduzione
If you have a faulty fan on your HP Pavilion 15-p046nr, you’ve come to the right place. This guide will walk you through how to replace your notebook’s fan. You may need to replace your fan if your laptop is experiencing overheating problems or if it is being excessively loud and creating high-pitched noises. You will need a magnetic project mat, Phillips 00 screwdriver, and plastic opening tool for this replacement. Be sure to completely disconnect power from your device before getting started.
Cosa ti serve
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
Remove screw covers from the hinge covers on the upper left and right side.
Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
Remove hinge covers by pulling up and out on the top of the cover.
Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
Grab the disk drive on the left side and pull the disk drive out completely.
Flip the laptop over and open the display.
Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the three ribbon cables on the bottom right corner of the motherboard.
Grab each ribbon cable and gently pull away from the socket.
Move the ribbon cables away from the motherboard.
Flip the motherboard over so that the fan is visible.
Carefully pull out the power cable that connects the fan to the motherboard.
Move the power cord away from the motherboard.
5 Commenti
Great!!!! Haber encontrado este tutorial antes, no obstante muchas gracias, está Genial, Like!!!
Good guide. But how come when I tried pulling my disc drive it wouldn't come out? I didn't want to force it.
Thanks again. Things are done FROM THE TOP of the laptop. Not the bottom. You don't open this from underneath like I was beginning to think.....
Can you provide me with a link how to replace the RAM for this same model?
My fan is a bit stiff but rotates so I don't think it needs replacement.
