Salta al contenuto principale
HP Pavilion 15-p046nr Battery Replacement
  1. HP Pavilion 15-p046nr Battery Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion 15-p046nr Battery Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion 15-p046nr Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Battery Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-p046nr Battery Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-p046nr Battery Replacement: passo 2, immagine 3 di 3
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 448
