Salta al contenuto principale
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 2
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 2, immagine 2 di 2
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, immagine 3 di 3
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 57
