Salta al contenuto principale
HP Pavilion 15-p Optical drive Replacement
Cosa ti serve
  1. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: passo 1, immagine 1 di 3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: passo 1, immagine 2 di 3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: passo 1, immagine 3 di 3
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: passo 2, immagine 1 di 3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: passo 2, immagine 2 di 3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: passo 2, immagine 3 di 3
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Optical drive Replacement, Remove the battery: passo 3, immagine 1 di 2 HP Pavilion 15-p Optical drive Replacement, Remove the battery: passo 3, immagine 2 di 2
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Optical drive Replacement, Remove the screw: passo 4, immagine 1 di 3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: passo 4, immagine 2 di 3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: passo 4, immagine 3 di 3
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once this screw is removed.
  5. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: passo 5, immagine 1 di 2 HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: passo 5, immagine 2 di 2
    • Remove the screws holding the optical drive bracket onto the drive. To do this, use a Phillips #0 screwdriver.
  6. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: passo 6, immagine 1 di 3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: passo 6, immagine 2 di 3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: passo 6, immagine 3 di 3
    • Be careful not to break any clips. The faceplate will still be usable, but will be loose fitting.
    • To remove the faceplate, open the optical drive with a paper clip. Once the tray is released, use a flat tool to release the visible clip on the faceplate. Once done, the faceplate should come off.
Conclusione
Altre 3 persone hanno completato questa guida.
Nick
Membro da: 11/10/09
93.444 Reputazione
59 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.698 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 7,658
