Salta al contenuto principale
HP Pavilion 15-n232nr Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-n232nr Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: passo 3, immagine 2 di 2
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  4. HP Pavilion 15-n232nr Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement: passo 4, immagine 2 di 2
    • Flip the laptop to the front side and open it up.
  5. HP Pavilion 15-n232nr Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use the metal spudger to release the keyboard from the front panel.
  6. HP Pavilion 15-n232nr Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 6, immagine 3 di 3
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  7. HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: passo 7, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: passo 7, immagine 2 di 2
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  8. HP Pavilion 15-n232nr Hard Drive Replacement: passo 8, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement: passo 8, immagine 2 di 2
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  9. HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: passo 9, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: passo 9, immagine 2 di 2
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  10. HP Pavilion 15-n232nr Hard Drive Replacement: passo 10, immagine 1 di 2 HP Pavilion 15-n232nr Hard Drive Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  11. HP Pavilion 15-n232nr Hard Drive Replacement: passo 11, immagine 1 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 11, immagine 2 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 11, immagine 3 di 3
    • Carefully use the iFixit opening tool to release the front panel.
  12. HP Pavilion 15-n232nr Hard Drive Replacement: passo 12, immagine 1 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 12, immagine 2 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 12, immagine 3 di 3
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  13. HP Pavilion 15-n232nr Hard Drive Replacement: passo 13, immagine 1 di 1
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  14. HP Pavilion 15-n232nr Hard Drive Replacement: passo 14, immagine 1 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 14, immagine 2 di 3 HP Pavilion 15-n232nr Hard Drive Replacement: passo 14, immagine 3 di 3
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
Conclusione
Altre 6 persone hanno completato questa guida.
2 Commenti
How to test it's processor
Kashmir Singh - Replica
Great guide, thank you!!
alt255d - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,479
