Salta al contenuto principale
HP Pavilion 15-eg0025nr Battery Replacement
Cosa ti serve
  1. HP Pavilion 15-eg0025nr Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Unplug and turn off the laptop before removing the back panel
    • Flip over the computer so that the back panel is facing upwards.
    • Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
  2. HP Pavilion 15-eg0025nr Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-eg0025nr Battery Replacement: passo 2, immagine 2 di 2
    • Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
    • This may be difficult if it is your first time removing them.
    • Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
  3. HP Pavilion 15-eg0025nr Battery Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-eg0025nr Battery Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-eg0025nr Battery Replacement: passo 3, immagine 3 di 3
    • Slide the opening pick around the edges of the laptop where the chassis has a seam.
    • You will hear a clicking noise as you undo the clips of the chassis.
    • It may be easier to start with the four corners of the laptop, and then follow through with the sides.
  4. HP Pavilion 15-eg0025nr Battery Replacement: passo 4, immagine 1 di 1
    • Remove the back panel completely.
    • With the back panel removed, you can now access parts of the laptop such as the fan or the battery.
  5. HP Pavilion 15-eg0025nr Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the five screws from the battery using a Phillips #00 screwdriver.
  6. HP Pavilion 15-eg0025nr Battery Replacement: passo 6, immagine 1 di 2 HP Pavilion 15-eg0025nr Battery Replacement: passo 6, immagine 2 di 2
    • Remove the battery from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 784
