Salta al contenuto principale
HP Pavilion 15-e043cl Wi-Fi Card Replacement
Cosa ti serve
  1. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
  2. HP Pavilion 15-e043cl Wi-Fi Card Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Lift the battery up and out of the device by the inward-facing edge.
  3. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: passo 3, immagine 1 di 3 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: passo 3, immagine 2 di 3 HP Pavilion 15-e043cl Wi-Fi Card Replacement, Maintenance Panel: passo 3, immagine 3 di 3
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
  4. HP Pavilion 15-e043cl Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the white and black mini jumper cable attached to the Wi-Fi card.
  5. HP Pavilion 15-e043cl Wi-Fi Card Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-e043cl Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Remove the single 2.5 mm screw with a Phillips #0 screwdriver from the Wi-Fi card.
    • Lift the Wi-Fi card out of the device.
Conclusione
Cace Letendre
Membro da: 10/25/22
519 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 100
