Salta al contenuto principale
HP Pavilion 15-d035dx USB Port Replacement
Cosa ti serve
  1. HP Pavilion 15-d035dx USB Port Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion 15-d035dx USB Port Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion 15-d035dx USB Port Replacement, Battery: passo 1, immagine 3 di 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx USB Port Replacement, Front Panel: passo 2, immagine 1 di 1
    • Begin by laying the laptop on its backside with the bottom of the laptop facing you.
  3. HP Pavilion 15-d035dx USB Port Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-d035dx USB Port Replacement: passo 3, immagine 2 di 2
    • There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
    • Continue by unscrewing all of them using a 0 Phillips screwdriver.
  4. HP Pavilion 15-d035dx USB Port Replacement: passo 4, immagine 1 di 3 HP Pavilion 15-d035dx USB Port Replacement: passo 4, immagine 2 di 3 HP Pavilion 15-d035dx USB Port Replacement: passo 4, immagine 3 di 3
    • Take off the back panel by removing the 4.0x4.7mm Philips head screw.
    • Then using the opening tool, work around the edges to pull off the back panel.
    • It will take some force to get the back panel off.
  5. HP Pavilion 15-d035dx USB Port Replacement: passo 5, immagine 1 di 1
    • Now flip the computer right side up and open up the laptop.
    • You should be facing the screen and keyboard.
  6. HP Pavilion 15-d035dx USB Port Replacement: passo 6, immagine 1 di 1
    • Now using the opening tool remove the front panel from the back panel.
    • It should start to pop off, you will have to do this step around the entire computer.
    • It will give some resistance so take your time to ensure that nothing breaks.
  7. HP Pavilion 15-d035dx USB Port Replacement: passo 7, immagine 1 di 1
    • Once you have popped off the panel it should simply be able to lift off of the laptop.
    • Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
    • You can replace the front panel now.
  8. HP Pavilion 15-d035dx USB Port Replacement, USB Port: passo 8, immagine 1 di 1
    • The USB Hub will be on the right side of the HP Pavilion Laptop.
  9. HP Pavilion 15-d035dx USB Port Replacement: passo 9, immagine 1 di 1
    • There will be two screws (4.0x4.7mm) that need to be removed so lift the Hub away from the computer.
  10. HP Pavilion 15-d035dx USB Port Replacement: passo 10, immagine 1 di 1
    • Next disconnect the flat cable by pulling the cable straight out of the connector from the USB Hub.
Conclusione
Stone Morris
Membro da: 09/25/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,232
