Salta al contenuto principale
HP Pavilion 15-d017cl Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Flip the laptop onto its back in order to have access to the back "L" shaped panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  2. HP Pavilion 15-d017cl Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-d017cl Hard Drive Replacement: passo 2, immagine 2 di 2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  3. HP Pavilion 15-d017cl Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the fifteen (15) 5 mm screws using the Phillips #1 Screwdriver.
  4. HP Pavilion 15-d017cl Hard Drive Replacement: passo 4, immagine 1 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 4, immagine 2 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 4, immagine 3 di 3
    • Flip the computer over so the screen and keyboard are showing.
    • Using the opener tools, pry around the edges of the computer in between the keyboard and the base.
    • Apply enough pressure to unlatch the keyboard but be cautious of the parts under it.
    • Flip the keyboard up toward the screen to access the motherboard.
  5. HP Pavilion 15-d017cl Hard Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using the Spudger, press into the silver latch and lift it up.
    • Using the Tweezers, pull the Ribbon Cable out of the silver latch.
  6. HP Pavilion 15-d017cl Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion 15-d017cl Hard Drive Replacement: passo 6, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the three screws located around the hard drive.
    • When finished unscrewing, pull the hard drive out.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,345
