Salta al contenuto principale
HP Pavilion 15-cd040wm Back Cover Disassembly
Cosa ti serve
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, immagine 1 di 2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, immagine 2 di 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: passo 2, immagine 1 di 2 HP Pavilion 15-cd040wm Back Cover Disassembly: passo 2, immagine 2 di 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: passo 3, immagine 1 di 3 HP Pavilion 15-cd040wm Back Cover Disassembly: passo 3, immagine 2 di 3 HP Pavilion 15-cd040wm Back Cover Disassembly: passo 3, immagine 3 di 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Joe Krawczyk
Membro da: 11/01/19
397 Reputazione
2 Guide realizzate
3 Commenti
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Replica
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Replica
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 117
Tutti i Tempi: 8,565
