Salta al contenuto principale
HP Pavilion 15-cc023cl Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-cc023cl Hard Drive Replacement: passo 3, immagine 2 di 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-cc023cl Hard Drive Replacement: passo 4, immagine 2 di 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. HP Pavilion 15-cc023cl Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to pry the hard drive out.
  7. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 7, immagine 1 di 1
    • Disconnect the hard drive cable.
  8. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 8, immagine 1 di 1
    • Lift the plastic wedges up on both sides of the hard drive.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,191
