Salta al contenuto principale
HP Pavilion 15-ca2073cl RAM Replacement
Cosa ti serve
  1. HP Pavilion 15-ca2073cl RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-ca2073cl RAM Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl RAM Replacement, Battery: passo 3, immagine 1 di 2 HP Pavilion 15-ca2073cl RAM Replacement, Battery: passo 3, immagine 2 di 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl RAM Replacement, RAM: passo 4, immagine 1 di 3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: passo 4, immagine 2 di 3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: passo 4, immagine 3 di 3
    • Pull the silver tabs on either side of the RAM outward.
    • Pull the RAM stick out of its slot.
  5. HP Pavilion 15-ca2073cl RAM Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-ca2073cl RAM Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-ca2073cl RAM Replacement: passo 5, immagine 3 di 3
    • Pull the tabs outward on either side of the second RAM stick.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 246
