Salta al contenuto principale
HP Pavilion 15-bk020wm Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: passo 1, immagine 1 di 2 HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: passo 1, immagine 2 di 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-bk020wm Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-bk020wm Hard Drive Replacement: passo 2, immagine 3 di 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Hard Drive Replacement: passo 3, immagine 1 di 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Remove the hard drive from the laptop.
    • Our device did not contain a hard drive.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 17,103
