Introduzione
This guide will show you how to replace the WLAN Module in a HP Pavilion 15-b109wm. This will take between 30-45 minutes, if done correctly. Remember to be careful and take your time since you will be working near the motherboard.
Cosa ti serve
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
Using a JIS #1 screwdriver, remove the five 5mm screws.
Detach the power button cable.
Detach the touch pad cable.
