Salta al contenuto principale
HP Pavilion 15-b109wm Fan Replacement
Cosa ti serve
  1. HP Pavilion 15-b109wm Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Fan Replacement: passo 2, immagine 1 di 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Fan Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 3, immagine 3 di 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Fan Replacement: passo 4, immagine 1 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 4, immagine 2 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 4, immagine 3 di 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Fan Replacement, Keyboard: passo 5, immagine 1 di 2 HP Pavilion 15-b109wm Fan Replacement, Keyboard: passo 5, immagine 2 di 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Fan Replacement: passo 6, immagine 1 di 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Fan Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Fan Replacement: passo 8, immagine 1 di 2 HP Pavilion 15-b109wm Fan Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Fan Replacement: passo 9, immagine 1 di 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Fan Replacement: passo 10, immagine 1 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 10, immagine 2 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 10, immagine 3 di 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, immagine 1 di 3 HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, immagine 2 di 3 HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, immagine 3 di 3
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Fan Replacement: passo 12, immagine 1 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 12, immagine 2 di 3 HP Pavilion 15-b109wm Fan Replacement: passo 12, immagine 3 di 3
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Fan Replacement: passo 13, immagine 1 di 1
    • Carefully remove the fan from its slot.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 482
