Salta al contenuto principale
HP Pavilion 15-ay041wm Optical Disc Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 2, immagine 2 di 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, immagine 3 di 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Disc Drive: passo 4, immagine 1 di 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, immagine 3 di 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
81.824 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
Un commento
Might add “Optical” to drive title to save some confusion.
mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 570
