Salta al contenuto principale
HP Pavilion 15-ay041wm Battery Replacement
  1. HP Pavilion 15-ay041wm Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-ay041wm Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-ay041wm Battery Replacement: passo 2, immagine 2 di 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Battery Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-ay041wm Battery Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-ay041wm Battery Replacement: passo 3, immagine 3 di 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
Conclusione
2 Commenti
Hello, I have a similar model, HP 15-ay039wm. I purchased a replacement battery from ifixit. Original was 10.9V and description of the replacement said it was 11V, but it says 14V on the replacement. Main problem is that it won’t charge and the laptop doesn’t seem to recognize it. I’ve tried a few fixes such as power reset but have NOT updated the BIOS. Any suggestions? Thank you!
JoV - Replica
When charger cord is not plugged in to the notebook the lab top will not turn on
Terri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 984
