Salta al contenuto principale
HP Pavilion 15-au123cl RAM Replacement
Cosa ti serve
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-au123cl RAM Replacement: passo 2, immagine 2 di 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - Replica
  3. HP Pavilion 15-au123cl RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-au123cl RAM Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - Replica
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - Replica
  4. HP Pavilion 15-au123cl RAM Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-au123cl RAM Replacement: passo 4, immagine 2 di 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - Replica
  5. HP Pavilion 15-au123cl RAM Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-au123cl RAM Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-au123cl RAM Replacement: passo 5, immagine 3 di 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: passo 6, immagine 1 di 2 HP Pavilion 15-au123cl RAM Replacement, RAM: passo 6, immagine 2 di 2
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: passo 7, immagine 1 di 1
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S13-G3, Cagle Fall 2017 Membro di USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Membri
6 Guide realizzate
Un commento
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,272
