Salta al contenuto principale
HP Pavilion 15-au123cl Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-au123cl Hard Drive Replacement: passo 2, immagine 2 di 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-au123cl Hard Drive Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-au123cl Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Hard Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion 15-au123cl Hard Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion 15-au123cl Hard Drive Replacement: passo 5, immagine 3 di 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: passo 6, immagine 3 di 3
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: passo 7, immagine 1 di 1
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: passo 8, immagine 1 di 2 HP Pavilion 15-au123cl Hard Drive Replacement: passo 8, immagine 2 di 2
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: passo 9, immagine 1 di 2 HP Pavilion 15-au123cl Hard Drive Replacement: passo 9, immagine 2 di 2
    • Pull off the plastic wedges on both sides of the hard drive.
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team S13-G3, Cagle Fall 2017 Membro di USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,667
