Salta al contenuto principale
HP Pavilion 15-au123cl Fan Replacement
Cosa ti serve
  1. HP Pavilion 15-au123cl Fan Replacement, Fan: passo 1, immagine 1 di 2 HP Pavilion 15-au123cl Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Remove the ten screws from the back case with a Phillips #0 screwdriver.
    • Using a plastic opening tool, pry the CD drive from the computer.
    • Remove the back panel from the computer.
  2. HP Pavilion 15-au123cl Fan Replacement: passo 2, immagine 1 di 1
    • Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
    • Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
    • Gently disconnect the fan cable cable.
    • Remove the fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 510
