Salta al contenuto principale
HP Pavilion 15-au123cl Display Replacement
Cosa ti serve
  1. HP Pavilion 15-au123cl Display Replacement, Display Screen: passo 1, immagine 1 di 1
    • Carefully wedge a plastic opening tool between the edges of the screen to.
    • While the tool is underneath the edges, move the tool around the screen to remove the black bezel.
  2. HP Pavilion 15-au123cl Display Replacement: passo 2, immagine 1 di 1
    • Remove the four screws (one in each corner) with Phillips #0 screwdriver.
  3. HP Pavilion 15-au123cl Display Replacement: passo 3, immagine 1 di 1
    • Detach the ribbon cable from the back side of the screen.
    • When you have detached the ribbon cable from the back side, remove the display from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 714
