Introduzione
We will be removing the back panel and then removing the battery. Before you do any major hardware modifications to the laptop, it is important to remove the battery first. Once removed, further modifications are much safer.
Strumenti
Parti
Nessuna parte specificata.
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
Altre 12 persone hanno completato questa guida.
2 Commenti
That one screw under the rubber pad is a special kind of BS.
The screw in the middle of everything was hardest for me to reinstall because it has to hold the CD drive in place ,and that drive hole must line up with everything else _just right_. Also, prying the keyboard from the shell was harder than I expected. It’s snapped in there pretty tight.
