Introduzione
This guide will show you how to access the cooling fan and replace it. The cooling fan is necessary to keep your laptop from overheating.
Cosa ti serve
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
To unclip the back of the case, I found I only had to free the 8 smaller clips in the battery compartment. The 4 larger ones seemed to be guides for reassembly.
Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place.
Use long nose tweezers to remove connector. Fan will lift out.
The connector is very small. Make a mental note of which way around it went in before removing it and make sure the replacement connector goes in the right way around. Care: make sure the wires do not obscure the screw hole to the top right of the connector. This female recess is for one of the screws removed in Step 5 and the wire could easily be damage on re-assembly.
Altre 2 persone hanno completato questa guida.
Before starting, open the CD drawer and leave it open. This makes Step 5 - sliding out the CD drive - far easier. If left closed, prying open the CD drive can damage it. Power down the laptop and begin.
Stuart - Replica
