Introduzione
This guide will show you how to access the cooling fan and replace it. The cooling fan is necessary to keep your laptop from overheating.
Cosa ti serve
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place.
Altre 2 persone hanno completato questa guida.
