Salta al contenuto principale
HP Pavilion 15-ab165us Fan Replacement
Cosa ti serve
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, immagine 1 di 2 HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, immagine 2 di 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: passo 2, immagine 1 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 2, immagine 2 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 2, immagine 3 di 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: passo 3, immagine 1 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 3, immagine 2 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 3, immagine 3 di 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: passo 4, immagine 1 di 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: passo 5, immagine 1 di 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: passo 6, immagine 1 di 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: passo 7, immagine 1 di 2 HP Pavilion 15-ab165us Fan Replacement: passo 7, immagine 2 di 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: passo 8, immagine 1 di 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: passo 9, immagine 1 di 1
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: passo 10, immagine 1 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 10, immagine 2 di 3 HP Pavilion 15-ab165us Fan Replacement: passo 10, immagine 3 di 3
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: passo 11, immagine 1 di 2 HP Pavilion 15-ab165us Fan Replacement: passo 11, immagine 2 di 2
    • Remove the fan from the motherboard.
Conclusione
Chad Christy
Membro da: 11/07/19
205 Reputazione
2 Guide realizzate
IUPUI, Team S3-G1, Harley Fall 2019 Membro di IUPUI, Team S3-G1, Harley Fall 2019
IUPUI-HARLEY-F19S3G1
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 602
