Salta al contenuto principale
HP Pavilion 15-AB153NR Cooling Fan Replacement
Cosa ti serve
  1. HP Pavilion 15-AB153NR Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Cooling Fan Replacement, CD/DVD Drive: passo 4, immagine 1 di 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 6, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 6, immagine 2 di 2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Cooling Fan Replacement, Bottom Case Cover: passo 7, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 8, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 8, immagine 2 di 2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 12, immagine 1 di 3 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 12, immagine 2 di 3 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 12, immagine 3 di 3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 13, immagine 1 di 1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 14, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 14, immagine 2 di 2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
  15. HP Pavilion 15-AB153NR Cooling Fan Replacement, Cooling Fan: passo 15, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement, Cooling Fan: passo 15, immagine 2 di 2
    • Disconnect fan cable from the motherboard.
  16. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 16, immagine 1 di 1
    • Remove both 3mm screws connected to the fan using Phillips #1 screwdriver.
  17. HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 17, immagine 1 di 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: passo 17, immagine 2 di 2
    • Remove the fan from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 565
