Salta al contenuto principale
HP Pavilion 15-AB153NR CD/DVD Drive Replacement
Cosa ti serve
  1. HP Pavilion 15-AB153NR CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  2. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  3. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 3, immagine 2 di 2
    • Slide the drive out from the right side of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 881
