Salta al contenuto principale
HP Pavilion 15 P Series Motherboard Replacement
Cosa ti serve
  1. HP Pavilion 15 P Series Motherboard Replacement, Shutdown Laptop: passo 1, immagine 1 di 1
    • Before working on the laptop, make sure it is shut down.
  2. HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: passo 2, immagine 1 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: passo 2, immagine 2 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: passo 2, immagine 3 di 3
    • Pull the locking tab to the right showing a unlocked symbol.
    • Then pull the release tab to the left, releasing the battery.
    • Lift the battery out of its connection.
  3. HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: passo 3, immagine 1 di 2 HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: passo 3, immagine 2 di 2
    • Unscrew the single Phillips #0 screw that holds the optical drive in place.
    • Using a spudger push the optical drive out.
    • Pull the optical drive completely out and set it to the side.
  4. HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: passo 4, immagine 1 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: passo 4, immagine 2 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: passo 4, immagine 3 di 3
    • Using a spudger, pry up the rubber cap.
    • Remove the single screw underneath the cap.
    • Slightly lift up on the marked section of the hinge cap. Pull away from the computer to release the cap.
    • Remove the hinge screw.
    • Repeat all steps on the other side.
  5. HP Pavilion 15 P Series Motherboard Replacement, Remove Bottom Screws.: passo 5, immagine 1 di 1
    • Remove each of the highlighted screws.
    • Note, this screw is sometimes covered by a cap.
    • Remove the silver pan head crew in the optical drive bay.
  6. HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: passo 6, immagine 1 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: passo 6, immagine 2 di 3 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: passo 6, immagine 3 di 3
    • Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself.
    • Follow all the way around the top case gently, until the keyboard is able to be lifted freely.
    • NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
    • Using your spudger, or prying tool lift the releases for each ribbon cable. *Be cautious when removing and handling ribbon cables as they are very fragile.
    • Lastly, remove the last two ribbon cables located at the top of the keyboard.
  7. HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: passo 7, immagine 1 di 3 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: passo 7, immagine 2 di 3 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: passo 7, immagine 3 di 3
    • Remove each cable and connection to the logic board.
    • Next, remove the screws holding the motherboard to the bottom case.
    • There may be a screw in this area, there was not in the computer I worked on.
    • Remove the screw holding the wifi card in place. Pull the wifi card out.
  8. HP Pavilion 15 P Series Motherboard Replacement, Finish Removing the Mother Board: passo 8, immagine 1 di 1
    • The hardest connection to remove, this is the cable to the AC/DC power port. Remove it by pulling the outside edges of the connector and wiggling gently.
  9. HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: passo 9, immagine 1 di 2 HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: passo 9, immagine 2 di 2
    • Remove the fan by disconnecting the white pin connector and then removing the only Phillips crew holding the fan in place.
    • Now you're ready to put the new logic board in!
Conclusione
Altre 8 persone hanno completato questa guida.
help
Membro da: 07/24/14
431 Reputazione
1 Guida realizzata
Out of a Jam Solutions Membro di Out of a Jam Solutions
Business
2 Membri
3 Guide realizzate
3 Commenti
Thanks for this guide. Apparently the RAM is on the underside of the logic board?
I have a HP 15-P189NA which could do with a RAM upgrade.
Douglas Bateman - Replica
Das Modell 15-P151NG ist etwas anders, hilft trotzdem die Anleitung.
Alex Barblexi - Replica
Ich wäre an dem defekten Mainboard interessiert.
Bernd Dreyer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 116
Tutti i Tempi: 15,209
