Salta al contenuto principale
HP Pavilion 14-q020nr Wi-Fi Card Replacement
Cosa ti serve
  1. HP Pavilion 14-q020nr Wi-Fi Card Replacement, Keyboard & Touchpad Panel: passo 1, immagine 1 di 2 HP Pavilion 14-q020nr Wi-Fi Card Replacement, Keyboard & Touchpad Panel: passo 1, immagine 2 di 2
    • Turn the laptop over.
    • Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
  2. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 2, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 2, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pry off the four rubber bumpers, located at the top corners and center of the back panel, off with a pair of tweezers.
    • Bumpers are delicate and can be easily ripped.
    • Unscrew the four 3mm screws under the bumpers using a Phillips Head 1 screwdriver.
  3. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 3, immagine 1 di 2 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Flip the laptop right side up and open the clamshell.
    • Starting at the bottom right corner, slide the opening tool into the crevice between the blue and silver panels.
    • Carefully pry the top casing up around the edges, moving counterclockwise.
    • Keep the tool steady throughout, as prying in a rough manner can break the casing.
    • You will hear audible clicking sounds as the clips connecting the two halves disconnect from each other.
  4. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Close the laptop and orient it on its side (clamshell hinge up), carefully holding it steady to ensure its safety.
    • Insert the opening tool inside of the hinge and pry with an even amount of force to disconnect the keyboard panel from the fan grate.
  5. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 5, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 5, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Reorient the laptop in an upright fashion and open the clamshell.
    • If needed, continue to pry the silver keyboard panel from the rest of the hardware with minimal force.
    • Slowly slide the silver keyboard panel towards you while lifting gently to separate the halves.
    • The panel is still connected by a series of delicate connectors glued to the mainframe, so do not pull the panel right off.
  6. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 6, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 6, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    • While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
    • With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
    • Unpeel the connector ribbon from its position on the motherboard.
  7. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 7, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 7, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 7, immagine 3 di 3
    • With your finger, flip up the white clasp that connects the larger keyboard connector to the motherboard, releasing the connector ribbon.
    • Gently pull the connector ribbon from the clasp.
  8. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Lift the keyboard panel up and away from the CPU, completely revealing the mainframe.
  9. HP Pavilion 14-q020nr Wi-Fi Card Replacement, Battery and Speakers: passo 9, immagine 1 di 1
    • With the internal hardware exposed, disconnect the battery cable from the motherboard.
    • If tightly fastened, gently wiggle the plug out of the jack.
  10. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 10, immagine 1 di 1
    • Remove the three 4mm screws around the perimeter of the battery pack with a Phillips Head 1 screwdriver.
  11. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 11, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 11, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 11, immagine 3 di 3
    • Flip up the two white clasps that hold the connector ribbon to the battery to release the ribbon.
    • Remove the 'motherboard to USB board' connector ribbon from its place.
  12. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 12, immagine 1 di 1
    • Detach the speaker cable from its fastener on the motherboard by pulling it out with your fingers or using a spudger.
  13. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 13, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 13, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 13, immagine 3 di 3
    • Using your fingers, gently pry out the two L-shaped speaker panels from between the external casing and battery pack.
    • Be sure to apply an evenly distributed upwards force on the speaker when lifting it out
    • Both speaker components (located adjacent to each other) will remain connected by a red cable after removal
  14. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 14, immagine 1 di 1
    • Lift out battery pack.
  15. HP Pavilion 14-q020nr Wi-Fi Card Replacement, Motherboard: passo 15, immagine 1 di 2 HP Pavilion 14-q020nr Wi-Fi Card Replacement, Motherboard: passo 15, immagine 2 di 2
    • Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
  16. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 16, immagine 1 di 1
    • Using your fingers, pull the cooling fan cable from its fastener on the motherboard
  17. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 17, immagine 1 di 1
    • Remove the 3mm screw that holds down the Wifi mini-PCI card using a Phillips Head 1 driver.
  18. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 18, immagine 1 di 1
    • Remove the three 3mm screws that hold the cooling fan in place using a Phillips Head 1 driver.
  19. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 19, immagine 1 di 1
    • In the upper right hand corner of the device, remove the 6mm screw holding the PCB board in place by using a Phillips Head 1.
  20. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 20, immagine 1 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 20, immagine 2 di 3 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 20, immagine 3 di 3
    • Remove the three 3mm screws from the surface of the motherboard using a Phillips Head 1.
  21. HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 21, immagine 1 di 2 HP Pavilion 14-q020nr Wi-Fi Card Replacement: passo 21, immagine 2 di 2
    • Carefully lift the motherboard up towards the screen as if it was hinged on one side.
    • To prevent possible scratching, cover the screen with a cloth.
  22. HP Pavilion 14-q020nr Wi-Fi Card Replacement, Wi-Fi Card: passo 22, immagine 1 di 2 HP Pavilion 14-q020nr Wi-Fi Card Replacement, Wi-Fi Card: passo 22, immagine 2 di 2
    • Using your fingers, pull the Wi-Fi card located on the right side of the detached motherboard out of its place.
Conclusione
Jenell Chase
Membro da: 09/11/17
210 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 211
