Salta al contenuto principale
HP Pavilion 14-q020nr Screen Replacement
Cosa ti serve
  1. HP Pavilion 14-q020nr Screen Replacement, Screen: passo 1, immagine 1 di 1
    • With the laptop facing you, open the clamshell. Be sure to turn the power off using a long press before beginning.
    • Remove the screw covers on both sides of the screen bezel by sliding a metal spudger into the crevice and gently peeling the cover away.
    • If the laptop turns on at any point during the repair, quickly turn it off with a long press
  2. HP Pavilion 14-q020nr Screen Replacement: passo 2, immagine 1 di 1
    • Remove both 4mm screws using a Phillips Head 1 screwdriver
  3. HP Pavilion 14-q020nr Screen Replacement: passo 3, immagine 1 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 3, immagine 2 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 3, immagine 3 di 3
    • Snap off the screen bezel by prying with your fingers in between the bezel and the screen.
    • Continue around the screen, gently prying and lifting.
    • You will hear a series of audible clicks as the bezel disconnects from the other hardware.
  4. HP Pavilion 14-q020nr Screen Replacement: passo 4, immagine 1 di 1
    • Carefully loosen the bottom bezel. Eventually it will snap free from the rest of the clamshell.
    • Pull hinge up and forward to detach it from the Chromebook. The bezel and hinge cover will remain attached.
  5. HP Pavilion 14-q020nr Screen Replacement: passo 5, immagine 1 di 2 HP Pavilion 14-q020nr Screen Replacement: passo 5, immagine 2 di 2
    • Remove the four 4mm screws within the metal tabs on the top and bottom of the screen using a Phillips Head 1 screwdriver.
  6. HP Pavilion 14-q020nr Screen Replacement: passo 6, immagine 1 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 6, immagine 2 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 6, immagine 3 di 3
    • Gently pry the metal tabs off of the screen assembly while holding the screen to unlock them.
    • Grab the screen by its unlocked tabs and tilt it down and away from the screen assembly, laying it down.
    • The new screen may scratch, to avoid this put a cloth down on the keyboard before laying down the screen.
  7. HP Pavilion 14-q020nr Screen Replacement: passo 7, immagine 1 di 2 HP Pavilion 14-q020nr Screen Replacement: passo 7, immagine 2 di 2
    • Peel off the barcode sticker to reveal the screen connector plug.
  8. HP Pavilion 14-q020nr Screen Replacement: passo 8, immagine 1 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 8, immagine 2 di 3 HP Pavilion 14-q020nr Screen Replacement: passo 8, immagine 3 di 3
    • Slide the connector out from its plug on the screen using your fingers to completely disconnect the screen.
    • Using your fingers, slide the connector out from its plug attached to the screen to completely disconnect the old screen panel
Conclusione
Jenell Chase
Membro da: 09/11/17
210 Reputazione
2 Guide realizzate
4 Commenti
Where did you find a replacement screen?
Grant McPherson - Replica
We are only showing how to replace the screen, we did not actually purchase a new screen for this guide.
Samantha Esqueda -
i have a multi layered line going down the middle of my screen how would i go about fixing something like that?
aaron kremer - Replica
Sorry, we are only knowledgeable on how to replace the screen, not on the issues.
Samantha Esqueda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 459
