Introduzione
Over time, Chromebook batteries may die, leaving it unable to charge. Speakers are sensitive and can get blown out after long use on full volume. This guide will show you how to remove the internal parts: the battery and the speakers, with prerequisite guide for removing keyboard panel.
Cosa ti serve
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
With the internal hardware exposed, disconnect the battery cable from the motherboard.
If tightly fastened, gently wiggle the plug out of the jack.
Un commento
Thank you for your instructions!!! HP and Chromebook sites had nothing!!! Sure they had instructions but nothing regarding how to remove the battery. The only instruction read- -remove battery!!!! Drrrrrr
