Salta al contenuto principale
HP Pavilion 14-n018us Display Assembly Replacement
Cosa ti serve
  1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 14-n018us Display Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: passo 2, immagine 1 di 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: passo 2, immagine 2 di 3 HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: passo 2, immagine 3 di 3
    • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
    • Use the plastic spudger and loosen the display away from the back of the screen.
    • Continue to use the spudger to detach the small plastic detents holding the screen in place.
    • Disconnect the display cable and remove the screen.
  3. HP Pavilion 14-n018us Display Assembly Replacement: passo 3, immagine 1 di 1
    • The screen can now be reassembled!
Conclusione
Michael Hollister
Membro da: 10/01/21
253 Reputazione
3 Guide realizzate
Casper College, Team 1-1, Lareau Fall 2021 Membro di Casper College, Team 1-1, Lareau Fall 2021
CASC-LAREAU-F21S1G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 210
