Salta al contenuto principale
HP Pavilion 14-cf0014dx SSD Replacement
Cosa ti serve
  1. HP Pavilion 14-cf0014dx SSD Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx SSD Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx SSD Replacement, Battery: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx SSD Replacement: passo 4, immagine 1 di 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx SSD Replacement, SSD: passo 5, immagine 1 di 2 HP Pavilion 14-cf0014dx SSD Replacement, SSD: passo 5, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  6. HP Pavilion 14-cf0014dx SSD Replacement: passo 6, immagine 1 di 2 HP Pavilion 14-cf0014dx SSD Replacement: passo 6, immagine 2 di 2
    • Carefully pull the SSD out of the slot.
Conclusione
Sam Cole
Membro da: 10/25/21
813 Reputazione
7 Guide realizzate
1Commento della guida
Hola!, ¿cómo es el cable para el SSD (Hard drive cable L23187-001), así como su case? (Hard drive cover L23219-001) La imagen que me aparece en la red del cable es muy largo. Gracias.
Ernesto P Mitre M - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 970
