Salta al contenuto principale
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
Cosa ti serve
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: passo 2, immagine 2 di 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: passo 3, immagine 1 di 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: passo 3, immagine 2 di 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: passo 3, immagine 3 di 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
Conclusione
Altre 2 persone hanno completato questa guida.
Joe Kennedy
Membro da: 01/23/17
231 Reputazione
2 Guide realizzate
Cal Poly, Team 22-8, Maness Winter 2017 Membro di Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 468
