Introduzione
This guide will walk you through the steps to replace the fan. Once able to access the fan, you may realize that you do not have to replace it: fans often overheat because the fan is blocked due to dust and other build up. We suggest cleaning the fan before completely replacing it in order to reduce any unnecessary costs.
Cosa ti serve
Locate these seven circled screws.
Remove the seven 5mm screws using the Phillips Head #1 Screwdriver.
