Salta al contenuto principale
HP Pavilion 14-c015dx Chromebook Battery Replacement
  1. HP Pavilion 14-c015dx Chromebook Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 14-c015dx Chromebook Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Set the lock switch to the orange unlocked position.
  2. HP Pavilion 14-c015dx Chromebook Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion 14-c015dx Chromebook Battery Replacement: passo 2, immagine 2 di 2
    • Slide the right side switch to the left so the battery sign does not show.
    • Once this switch is pushed, the battery will pop out slightly and you can pull the battery out completely.
Conclusione
Cal Poly, Team 22-8, Maness Winter 2017 Membro di Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 587
