Introduzione
Use this guide to replace the WLAN card in your HP Pavilion 14-bk061st laptop.
The WLAN card is a computer component that allows the device to connect to the internet through a wireless signal. In this computer, the WLAN card also handles Bluetooth connections. Bluetooth is another means of wireless communication most often used to connect and transmit information between devices that are in close proximity, usually about 30 feet or less.
Before using this guide, if there is an internet connection issue or Bluetooth connection issue, try using the built-in software diagnostic tools that your computer provides to see what the problem is first.
Remember to power off the computer, and disconnect all external components, including the power adapter, that are plugged into it before starting the repair.
Cosa ti serve
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
Altre 2 persone hanno completato questa guida.
