Salta al contenuto principale
HP Pavilion 14-bk061st WLAN Card Replacement
Cosa ti serve
  1. HP Pavilion 14-bk061st WLAN Card Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 14-bk061st WLAN Card Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st WLAN Card Replacement: passo 2, immagine 1 di 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st WLAN Card Replacement: passo 3, immagine 1 di 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st WLAN Card Replacement, WLAN Card: passo 4, immagine 1 di 2 HP Pavilion 14-bk061st WLAN Card Replacement, WLAN Card: passo 4, immagine 2 di 2
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  5. HP Pavilion 14-bk061st WLAN Card Replacement: passo 5, immagine 1 di 1
    • Remove the JIS #1 screw from the WLAN card.
  6. HP Pavilion 14-bk061st WLAN Card Replacement: passo 6, immagine 1 di 1
    • Remove the card by pulling it away from the slot.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 644
