Salta al contenuto principale
HP Pavilion 14-bk061st RAM Card Replacement
Cosa ti serve
  1. HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st RAM Card Replacement: passo 2, immagine 1 di 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st RAM Card Replacement: passo 3, immagine 1 di 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st RAM Card Replacement, RAM Card: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st RAM Card Replacement: passo 5, immagine 1 di 1
    • Remove the card by pulling it up and away from the slot.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure that that the card is fully inserted otherwise your computer may not work and the card may be damaged. If the card is not seated properly it may come out of its slot and hit other components inside the laptop when it is moved around.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 441
