Introduzione
Using this guide, you can replace the motherboard in your HP Pavilion 14-bk061st laptop.
The motherboard is the central connection between all the components of a computer. A faulty motherboard can lead to the whole computer failing so it is important to keep good care of all the components in your PC.
Cosa ti serve
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
Remove the seven screws from the motherboard using a JIS #1 screwdriver.
Altre 3 persone hanno completato questa guida.
