Salta al contenuto principale
HP Pavilion 14-b120dx Palm Rest Replacement
Cosa ti serve
  1. HP Pavilion 14-b120dx Palm Rest Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Palm Rest Replacement: passo 2, immagine 1 di 3 HP Pavilion 14-b120dx Palm Rest Replacement: passo 2, immagine 2 di 3 HP Pavilion 14-b120dx Palm Rest Replacement: passo 2, immagine 3 di 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Palm Rest Replacement, Keyboard: passo 3, immagine 1 di 3 HP Pavilion 14-b120dx Palm Rest Replacement, Keyboard: passo 3, immagine 2 di 3 HP Pavilion 14-b120dx Palm Rest Replacement, Keyboard: passo 3, immagine 3 di 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Palm Rest Replacement: passo 4, immagine 1 di 2 HP Pavilion 14-b120dx Palm Rest Replacement: passo 4, immagine 2 di 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Palm Rest Replacement, Palm Rest: passo 5, immagine 1 di 2 HP Pavilion 14-b120dx Palm Rest Replacement, Palm Rest: passo 5, immagine 2 di 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Palm Rest Replacement: passo 6, immagine 1 di 3 HP Pavilion 14-b120dx Palm Rest Replacement: passo 6, immagine 2 di 3 HP Pavilion 14-b120dx Palm Rest Replacement: passo 6, immagine 3 di 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Palm Rest Replacement: passo 7, immagine 1 di 1
    • Lift upwards to remove the palm rest.
Conclusione
UMass Dartmouth, Team 4-4, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 462
