Introduzione
This guide will walk you through replacing the audio port and USB drive card using an iFixit PH0 screwdriver and plastic opening tool.
Cosa ti serve
Insert the plastic opening tool between the keyboard and the palm rest.
Pry upwards until the keyboard section detaches from the laptop.
Repeat this around the edge of the entire keyboard.
Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
Carefully disconnect the cable connecting the ports to the motherboard from the right side.
Altre 2 persone hanno completato questa guida.
2 Commenti
where can I find the replacement part?
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
